wing and door removal????help
iam going to be removing my drivers door and wing and replacing them how easy is it and what tricks are there in doing this.
leave the hinges attatched to the front pillar and unbolt the hinges at the door.
The door stay has a pin in it that you need to tap out using a punch, it isnt very tight and it needs taping upwards.
But first remove the door panel , disconnect all the electrics at the multi plugs and pull the wiring out at the big grommet.
Wing removal is easy because they are bolted on but the front bumper is bolted to them, if you remove the plastic corner lights you can get up to these bolts with a socket set.
Hope this helps
Paul
