got a problem with clutch while driving when i went for next gear pressed clutch it went straight to floor and did not return, lost all pressure looked in resovoir and it was drained.
checked underneath and could see the slave cylinder had popped out which means the clutch arm had no pressure to keep it in place obviously something has gone inside clutch, is this a common problem if so what has happened.
the clutch was working perfectly before this happened.
had some quotes for a new clutch fitted, quite a hefty bill
would the thrust bearing have caused problem because it did make a bit of noise when depressing pedal if so could be cheaper way out or would this not be cost effective
p.s anyone know of a good garage that knows these cars in county durham cheers
