How much boost.......
will regular head gaskets take, before they exploderise?
Dont trust them damn yankees;) :D
Depends on the power you're running really.
Boost pressure is really not the issue, it's the cylinder pressure that's generated that maters and more power = more cylinder pressure.
OK then, how much power can you run with stock gaskets?
:rolleyes: :D
Well Adam,I would have your deck face mig wired,Peter has had problems with all the metal head gaskets available running high boost.He said the mig wire method works a treat.
might sound like an dumb question , but once this procedure has been done , if required can the heads still be removed without damage
PMSL Please tell me you don't think the heads are welded to the block?
Mig-Wire not fookin Mig-weld:rofl: ;)
told you I was a dumb ar5e mis read it .........honest :rolleyes: :D
LMAO!! like to see you trying to mig the head to the block Baggins!! :rofl:
