I want to stick some heat resistant matting to the underside of my plenum!
It is a cloth type material being stuck to metal and it has to withstand the heat from the Tubs and manifolds!
NE1 know where I could get this from?
DemonTweeks,if i remember rightly,allso in there motorsport catalog,will look for page for you and post it this afternoon if you not got one:)
That heat resistant matting wouldnt happen to be a bit of fire blanket that you er found at work would it :D:D
By some strange coincedence I damaged my firegear in a job and ripped out a plenum shaped hole in it!!!!:D :D :D
Not sure this is exactly what you need but i cant see no reason for it not to do the job:)
mark I can get hold of some d/side tape that is very good at heat rest we use it on sign before there sprayed there thay go in the oven. If you like to give it a go I can send you some or meet.
jay
Hi, go into your local Partco Motor Factors and ask for a tin of Bodyline Hi-Temp Trim Tack, use to come in a 1ltr tin and 250ml tin, from memory the Ltr tin was about £10.
