rear diff seal?
hi zed heads, my rear diff is leaking fluid, ive bought the seal (o/s) from nissan (£8) how easy is it to do, ive looked on the online manual and in past threds but nothing really tells me that its on a spline and you can just pull the driveshaft out and then tap the new seal back in?
has anyone done one before or know what it envolves?
many thanks
Jim.:)
many thanks
Jim.:)
mines leaking too. getting the parts soon.
not done one on a zed, but done loads on other cars.
after the propshaft is disconnected, theres 1 nut to undo, it will be quite tight & after that the flange will pull off (may need a puller for this)
thing to remember is this:
MARK THE NUT & FLANGE BEFORE REMOVAL!!
the diff is preloaded by a collapsable washer inside the diff, over tighten & theres no going back! if you mark it & tighten to the same place, all should be well.
we also check with a preload gauge at work, but marking it is just as effective IMO
hi paul, is'nt this for the propshaft seal?
mine the drivesaft o/s seal.
jim.:)
Cerina's Rear Diff is also leaking,
Would this cause a loss of power and slight vibration ?
Will be replacing it soon.
I don't think it's a hard job to do, maybe a little messy but not hard.
Check the FAQs link above and look at the manual there.
changing these seals is a piece of piss - unbolt the offenfing drive-shaft and use a rubber / leather mallet to knock the drive arm out of the diff. then pry the seal out with a screwdriver and replace with new one - inserting the thing into the diff is easy afterwards, and only takes a knock with the palm of the hand!
job done!
However, if its the prop-shaft end thats leaking you've got a lot more grief to deal with ! ref the online manual!
Simon,
CHEERS, simon yer mine is the drivshaft one!
cheers mate that helps alot!!
jim.;)
Jim do you have the part number for that Gasket.
Was it an NA or TT or are they both the same ?
hi stuart, the part number for the driveshaft oil seal is
38342-40poo from nissan (£8.00)
cheers
jim.;)
ps mines a TT dont know if their the same?, would have thought so.
