rear wheel woble !
jacked my car up and held the rear wheels and i could
physicaly move them side to side,
i think i need new bushes where is the best place to get them from, there is no listing at the z centre i had a look,
i think i need the rear lower arm bushes,
rear upper arm bushes
rear arm that goes around the strut !! bushes
i found these not sure if any good though anyone else tried them
http://www.superflex.co.uk/SuperFlex_Nissan_200SX,_300ZX-Z32_Prices.pdf
not sure which i need though??
I had the same kinda wobble and it was the ball joint. Quite a bit of side to side movement/play on my n/s rear wheel. This also caused it to hop/skip over potholes and stuff.
The part no 55154-30P00 £41:40+vat. Fitting is a little tricky.
could also be the Hicas link arm - you need to see where the movement is
cheers guys will look into it
thanks
dewi ap
