Quick shift
I've got an old gear stick to chop up to make a QS. I was just going to chop the botom off and extend it a bit.
Anyone done it? How much did you extend it by?
Had this from an American site:
ย
Let's say you want a 2"shorter throw, take the shifter and cut it right where the pivot ball and the top half meet (right above the pivot ball), then take the top part you just cut off and cut 2" off that, put the little 2" piece aside you will need it later, then re-weld the shortened part of the shifter back on the pivot ball. then take the shifter and cut just below the pivot ball...take the 2" piece the you cut off earlier and weld it to the pivot ball where you just cut off the bottom portion then re-weld the bottom portion to the 2" piece you just welded back on.
Now what you should have done if you did it right is shortened the shifter above the pivot ball 2" and lengthened the shifter below the ball 2".
LOL That confused the crap out of me the first time I read it.
got any pictures ?
Originally posted by SMW1
Top Dog.
Thanks mate ;)
ย
Stu, fancy using mine as a ginea pig ;) ;)
