While I am still confirming the signal coming out of the speedometer, I took a closer look at the gauge itself. After removing the gauge from the cluster housing I spotted some discoloration. This happens to be near a fairly sized electrolytic capacitor. I already spotted a trace that is potentially broken, so I began cleaning the area with a soft toothbrush. Sadly, even the softest bristles caused the solder mask to flake away. Since it didn't matter any more I switched to 2 jewelers cleaning brushes, one fiberglass and one nylon. Sure enough, the damage to the trace is more visible, but it passes under a resistor and I don't know where it leads. Removed the resistor, and unfortunately lost it, but thanks to the photos I know what its value was. Anyway, with the resistor out of the way we can see that the trace is definitely broken, and simply passes under where the resistor was. Now that its confirmed, it has been patched using some thin wire and the resistor replaced with a 10k through-hole that I had. Also attempted to tin the exposed copper traces while I was at it. Admittedly, this will need a little cleanup before I re-seal the board, but it should help at least slow down any more deterioration of that section of traces. I've already reattached the board to the gauge and put it back into the cluster. I'll be testing it later when the sun is up.
By
Silver · 6 hours ago 6 hr
hi guys i took my car to the garage and had the problem with the back of the car shifting to one side when i went over a small hump any way it turned out to be the track rod arm that goes into the rear steering rack can any one tell me how to take one off and fitt a new one any help thanx..........as always
