Clutch problem
Hi all,
Bit of an odd clutch problem. The point where the clutch bites moved overnight - so much so that it was very difficult to get the car into 1st gear now and all other gears are a bit of an effort.
Checked the fluid reservoir which was below the minimum, topped it up, bled the circuit (which seemed to be ok) and no difference. I've adjusted the pedal to maximum now so the car is driveable.
S'pose I must have a leak with the reservoir being empty but it's not gone down since I topped it up last....
Any ideas??
Cheers!
RobH
Is this where the "bite" point suddenly sort of clunks and shifts by an inch or so. And then you notice later on, it's back where it was?
if the hydraulic system is ok & bled properly, it could be a broken clutch cover :(
Hi guys, thanks for the replies, it's actually that the clutch doesn't operate until the pedal's an inch closer to the floor than it used to be.
We had a proper look at it today and it looks like a leaky slave cylinder. Ho hum.
RobH
