Bad Idle and detonation
Last weekend i reset the ECU to try and solve a problem with the idle dipping and surging. This has improved slightly, but it still dips and surges whenever Im at a standstill.
However, from Monday to Thursday, I only ran it on Optimax.
The difference in acceleration now is amazing. The boost gauge (aftermarket) says that the car is producing 17 psi of boost. I dont believe this is wholly accurate. :)
However, Thursday evening I had to put some standard unleaded in as I was too far from any shell garage. Detonation occured well before max boost was achieved. About 15 PSI on the gauge.
So yesterday evening I put in some Super Unleaded. Detonation occured just before max boost.
Now, the only engine mods that I am aware of, are the SS Exhaust, K&N Filters (Now vv clean) and the chipped ECU and 0.8mm boost jets fitted by Zedworld. As I have inherited a complete history of the car since it was imported, I believe these to be the only engine mods.
Is it normal to det on Super Unleaded? And how much detonation will kill the pistons?
edit :- One more thing, it now feels much more powerfull than when I had it on the SE Rolling road. Roll on the next one! ;)
sounds like a vaccum leak to me. I would check the pipework around the boost jet install. If your boost is going too high check the jets are not blocked with anything. There is a tech item on TT net with the correct method of fitting boost jets.
surely this is a good reason for fitting an electronic boost controller.................
Vijay
I would be very careful if I were you!
I have fitted boost jets to about 12 Z's and I have never used less than 1mm jets.
0.8mm is going to give just what you are getting - 17 to 18psi!
This is way too high as you shouldn't be going past about 15psi on your setup.
Get them changed to 1mm or bigger. Better still, get a controller.
You certainly need to be using Optimax and take it easy before detonation kills a piston!
Chris.
