bought these k&n racing filters to go on the se-nissan maxiflow twin pop kit, and on the box it says:-
for off road use only and marine applications
not for emission controlled vehicles !!
are they safe to use on my zed?? its a 1990 with a de-cat so emmisions are not that much of a problem!!
No problem - it's a typical warning that is found
on a lot of after-market stuff.
Are you planning to go to a high bhp?
yep i certainly am, i did have the se-nissan intake and thought it would be better to use the k&n filters instead of the filters that came with the se-kit,
they certainly look the buisness will take some pics once i get my damn camera to work!!
hurry up i want to see:D :dance: :dance: :dance:
Which model / part number are they - was thinking of doing the same myself.
the filters i used were the k&n RU2820
sorry i cant get any pics at the mo!
this is the way i did it, on the se-nissan intake u will find that it is 2 pieces sandwiched 2gether with a rib all the way round it,
the origional filters are a 70mm neck, now then i caerfully cut back a little bit of the rib on either side of the neck of the intake to allow the k&n to fit over, as the k&n has a 76mm neck just nice for fitting over it!,
i sent an e-mail to K&n 2 ask about the off road statement and this was the reply:-
Thank you for your enquiry. The off road/emission controlled situation applies mainly to USA . You have no problems in using them on or off road and no damaged will occur. The main difference is that the filter neck is heavier duty to withstand lots of vibration as would apply in an off road situation.
Regards
Don Marshall
i bought the filters from here : http://www.filterpower.co.uk
i only got the one, the other is on back order a 4 weeks wait but well worth it.
pics soon as it arrives !!
dewi ap
