tyre pressures?
picked up 1990T/T on friday. 2 days of grinning later:D, decided to change crap jap rubber with some decent stuff.
does anyone know the correct pressures for these tyre sizes
235/45x17 & 255/40x17
tyre fitter put in 32 & 33 psi but think thats too much!
cheers
nick
Standard pressures are 36 rear, 33 front. Yours may vary a little with different sized tyres - experiment and see what 'feels' right.
Nick
im running the same tyre sizes as you, and the pressures yours have been set to is the same as mine, and im having no problems
I too have the same sizes. I started with 1psi below factory settings and found this OK so far......:)
Incidentally when I had stock wheels and ran with factory settings, my rear tyres always wore down showing classic signs of overinflation:confused:
Too low and you will burn more fuel. Also the tyres will flex more and therefore overheat on a long high speed run (hence the owners manual suggests increasing pressures for continued 100mph driving) which could cause a blowout. Remember, the Zed is a heavy car hence the higher standard pressures.
Best start near standard pressures and reduce until it feels right.
Richard:)
