Anyone know the part Nos for the two heater matrix hoses at the back of the engine?
I only need the one that comes out of the bulkhead lowest!
It seems to have been cut by the jubilee clip as the hose enters the back of the engine.
Or what do I ask for! as the two of them are sods to change they are £14.50 each but I dont need both!
Can any one help if this makes sense?
Arthur,
I have a new set both top and bottom sat in the garage ready to go on , I will check out the part numbers when I go home for my lunch if no one has posted them before then.
Ryan
Thanx Ryan
will look at hoses lunch time so I get clear pictiure.
Arthur part numbers as promised
92410 - 30P00
92400 - 30P00 = Longer Hose
Ryan
Cheers for that Ryan,
I added 1.5L of antifreeze to the system before going to Torquay over w/end.
Temp fix of matrix hose (long) with some rubber tape. Check coolant level lunch time no coolant loss! But will change it anyway.
Arthur
Guys is this a common 'wear' point? I've had a cooland leak for 6 weeks now and its the bain of my life!
I suspected a stickey thermostat increasing the pressure then leaking past a hose connection but have looked at most and seem okay....Was going to replace my Stat this weekend...Is it worth me getting underneath and changing these hoses as my next suspision points towards a dodgy heater matrix as everything else seems ok!
Damian.
