Help needed please
Before I undo anything.
To change the front disc do I undo the two 19mm bolts at the back of the disc. ps Cannot get 300 org on site?
Z wheel off ready!
yeah, you take the two caliper bolts out, (19mm bolts), pull caliper clear, then you can set to getting the discs off the hub.
If you have trouble getting the disk off after the caliper is removed, I think there are a couple of bolt holes you can screw into which should shift it.
Steve
