I've a really irritating clicking coming from the clutch pedal somewhere,tried greasing everything and squirting WD40 everywhere,on closer inspection it seems to be coming from just behind the bulkhead,any idea's how to get rid of it,it's driving me nuts...........so are my squeaky brakes!!!!!!!!!!!!
I suggest you remove the steering wheel from your underpants :rofl:
is it a constant clicking? if so i had a similar problem while playing with the plugs on the gearbox ecu, try giving em a wiggle and see if it stops.:dance:
No in fact i drained out all the clutch fluid moved the pedal and it stopped,put in fresh fluid and when the pedal stiffened up it started again.....
