Actuator wastegate question
Two questions really:p
Firstly on the wastegate actuator hose one end goes to the boost controller the other end goes the actuator then there is a third hose teed off that goes to something else , what does it plumb in to , should this hose still be connected if using a boost controller ,
next I can only see this third hose on the passenger side actuator is there one on the drivers side ??
Ryan
The T section near the turbo wastegate goes to the stock boost control solenoid. This is on both sides.
You can disconnect the connector plugs to the stock boost control solenoids and plug the hose that T's off. Use a screw with some sealant to keep things simple.
The hose from each turbo actuator then meets with equal lengths of hose and connects to one of the ports on the boost controller solenoid.
Hope this helps.
Steve E :)
No need to plug the hose if you disconnect the solenoids.
Cheers guys :)
