Rear quarter damage
Take a look at the attch pic, shows a repair just completed on a nasty rear quarter damage, body shops are amazing.
Riverside bodyshop who done this repair do all our paint work, and I cannot reccomend them enough.
Jeff @Zedworld
Hi Jeff. How much did this repair cost? Mines damaged in exactly the same place! Pics are on Rides - Shaunmac - Damage1 - 3.jpg
I'll be getting Faisals Greddy kit fitted aswell though!!
Dave.
Must admit I'm underwhelmed!, most of that would push out easily from the other side, then easily finished with filler, pretty standard stuff from what I can see, thought it was going to be a really mangled pre accident pic!!
Paul N
Repair was £600 including repair to door and the paint too.
Jeff
Front end of same car;
It was damaged by the impact, pic shows it removed to gain access to pull the front panel.
Jeff
Yo Bro (DaveMac), maybe you could get that 99 spec front spoiler too, it looks 100 times better than the older one.
did they replace the slam bar?
Also I had an identicle dent pulled and repaired for about £150
Stu has seen what an excellent job they did :)
As it hold`s the fog light`s in place it is sort of required.
£150 for a similar repair?...not bad got a number could send him loads of work at those prices in fact could most likely get the whole of the midland`s accident and repair shops to send him their work too!
Comparing the extent of accident damage from photo? you could have a career in motor insurance assessing, no need to see the car just send a photo.
Jeff,
I had a similar sized dent removed, reprayed and blended in half way down the door, i also had some manky paint repaired around the window, I had rust removed from one t-bar, and rust taken out from below the rear windscreen wiper and blended in.
on the opposite side I had a score mark removed that went into the rear wheel arch, I also had rust removed from both wheel arches.
That cost me £280
They are in the not in the midlands though, they won't take on anythign to major as they are pretty much jammed solid with insurance work, They have a lovely ferrari dino in there at the moment along with an expensive looking jag
I wasn't happy with the T-bar repair however as that paint moved when I washed it two weeks later its abuot the size of a finger print. Of the people who have seen my car none have noticed the accident repair.
