protoj · 15 hours ago 15 hr
Hi Guys,
Car has just failed it's MOT on front worn tyres. :cry:
Anyone know where can I get hold of two cheap 235/45/17 tyres for the front of my zed. Had Bridgestone S02's on before but would like something cheaper this time if possible as I'm selling her soon.
Cheers for any help!!
Dean. :)
