HELP Please.......
Where is the best place to drill a hole through the fire-wall passenger side? I need to run two pipes and two wires into the engine bay. Got stuff through the bonnet release hole already.Need to drill a hole about 3/4"
You're not installing central heating with door mounted chrome radiators are you? ;)
Look just to the left of the batter and on the firewall. There is a hole which apears between the place where the ECU is and the glove compartment on the passenger side.
As Srrae says, that's the easiest place. If you remove the plastic arch liner, you'll see where it comes through. NO need to drill any holes, they're already there :)
Vijay
Cheerz for the advice M8,but not to clear at the mo.Is the hole between the ECU and Glove box looking from inside from pass side after removing the board.Left,right,centre?Is it being used by anything?Where dose it come out in engine bay?
Vinz, remove pasenger side footwell plastic panel, go out side car and remove couple of clips holding inner arch cover on below side repeater area,then in the engine bay go behind the battery. gromett is behind the platic trim in footwell, this goes behind inner arch, then up to a hole behind battery.
smithy :cool:
Vinz, cant find any pics that will help you, but I have found a pic of you sunning yourself at billing 2002!!:D ;)
