Front upper arms
I'm going to buy a set of front upper arms because 1 of mine is in bad condition and car is not stable when i hit the brakes moreover it's tearing my tires from the inside.I thinking of buying the tbo anyone got them are they good or you suggest another brand?
Whats a tbo?
For front top links you can get Nismo Skyline bushes from Middlehurst Nissan, St Helens. Did mine with them - Bushes were about £156 delivered. Not too difficult to do an uprate on standard and a lot cheaper than new top links.
Beware.
Dont use those pretty coloured things!!!
Do a search on top links. There are some horror stories about those very things bending for no apparent reason!
Well prolly a pothole but not a special one!
Design defect.
Saw piccys on here
At least with the Nismo stuff you know its Nissan approved
Just rechecked the piccys - not the same as the ones you are looking at but I have a feeling they get tarred with the same brush as the T style design puts huge stress on the joints.
Maybe my imagination but I thought there were piccys of bent coloured ones too somewheres.
I don't know i haven't take a search around i just saw them and liked them do you suggest anything else(What about the stllen's)? I want adjustables that's y i didn't replace the bushes.
Cant say I know enough to give good advice here abut at least Stillen is the right name for zed stuff.
Must be others here with adjustable top links that dont bend.
Otherwise you could rebuild yours and get shims to do the adjustments. Much simpler.
TBO units are considered the best ones to use ;) It was the noltec ones that were posted about - basically the same as the stillen ones. The stillen ones are slagged off for slipping, the noltec slagged off for breaking. Basically looked like a case of poor manufacture. The TBO style links are preffered as they do not slip.
