hicas light
what do i need to do
when i started the car today the hicas
light stayed on for about 30 seconds.
i drove it for about 30 miles and it did not
come on again is this usual?:confused:
your power steering fluid it probably gettin low
ill check in the morning
thanks mate
steve
I had this a couple of weeks back - just top it up with auto trans Dexron III fluid. Maybe contracting a little now it's turned chilly.
Topped up the p/s fluid but the light is still on.
HICAS screwed????.....
Do you think if a leak was present I would be able to see it?. And would it be noticable at stand still?.
Ok simple answer;) follow the wire coming out the lid of the P/S tank,then unplug that wire is the light still on?
Thanks guys.
Definatley not fluid. Still got the Diag to run.
