trying to test
trying to test the boost
afer fitting 1mm mig tips
have a boost gauge(borrowed off a mate) until i get one
cant seem to get it to work
got some info off tt zs of dallas
but cant find right pipe
steve:confused: :confused:
If its temporary, Tee into any of the pipes hanging directly off the balance bar. This will give true boost pressure at manifold.
StuartR
StuartR
Why is that only if its temporary? I plan to have mine there when I plumb it in properly... :confused:
Just saying you don't need to think about placing pipes, etc. for a temporary solution - quick and easy ;)
If you were to plumb one in permanently, I would certainly consider pipe routing, etc. And some of the vacuum hosing in that area won't give proper boost readings (e.g. if it comes from AIV solenoid, EGR, etc.)
