mig tips
i know there is loads of discussions on here about this subject.
but can any body tell me about there own experience of this
method of boost increase.
(good or bad)
thanks steve:confused:
been using them for over a year now - no probs at all :)
it does drop a little on full boost though, mine will boost to 16psi on full throttle, then will slowly drop to around 14psi. which is nice really, you get a nice overboost for flooring it then drops down a little.
got to be worth the dancing banana :dance: :D
(good or bad)
I put in new ecu & tips, the, it run like a piece of shit, so took out new ecu & put old 1 back, tips did not make any diffrence in or out.
now just trying to find out what to do next!
thanks mate what size are u using
couldnt get any biger than one mm
steve
i am using 1mm
tried 1.2mm ones 1st - that gave around 12psi of boost
just fitted took about 20mins
what a differnce, f@@@ing thing nearly wheelies
i like it,best 2quid ive ever spent.:) :D :) :D :) :D
Have you got a modified ecu? as with my standard ecu it dont feel any faster??
Are you getting detonation and what boost does your gauge say you're running (you have got an aftermarket gauge right?)
no i have a standard ecu
i havnt got an after market boost gauge yet
tried to get one this afternoon with no luck
took car up road once, now parked it up until
i cheak bost level
it went of the standard gauge,
but it nearly ran on max anyway.
not going any where in it until i check
steve
could be in safety boost - have you done a ecu error check??
should be quite noticable, even with a stock ecu. its just safer with an aftermarket chip
stevo
any chance of a photo of the place u put them in
wez
No i have not done ecu error check, is it easy??
Is it risky running it without modified ecu??
no i have not got after market gauge & is detonation "blow up"?
stevo
just done it with 1.2 tips 20mins thats with a brew and one cut hands.just give it a run down the east lancs very nice
thanks for the help
wez
:dance:
