Got some carb cleaner and gave the throttle bodies a quick clean last night! I think I did it all properly, took off the pipes, opened them up, loosened all the black cack off with a toothbrush, wiped it clean with a soft cloth, put everything back together and then screwed it all up tight again!!
My problem is that the idle is now at about 1000rpm instead of 7-800 as it was before. Do you think it will drop after a few drives or should I reset/adjust something??
The car runs and accelerates fine! Although I did get blasted by an 03 porsche 911 turbo last night, mind you when we were stopped at the lights he did mention that it's not very often that he needs to boot it to leave people!!:D :D :D
mm-m-m-us-sst haaav-v-ve m-m-mor-re POWER!!!!!:D
