Finally got the Zed running again (sadly a day after the Chester Meet!!), but there's one small problem...
I've managed to 'lose' the rubber insert from the spark plug socket - and eventually found it wrapped around a spark plug!!
Anyone had a similar problem, or am i Gonna have to figure this one out for myself?!?
undo spark plug as usual then use the coilpack to retreive it. simple
hmmm, not quite so simple! the rubber bit's so rammed on, I can't get another socket on it!!
thought about trying to cut it away, but not to keen on all the bits going inside...
I just need something long enough to grab it, but normal 'grabbers' are too wide!
cut it off then make a skinny attachment to tape to the end of a hoover. surely the socket from which the rubber came from fits back over the rubber
usually would, but as i didn't realise it was stuck round the plug i tried another spark plug socket and did a really good job of gettin it stuck fast!!
sure i'll figure a way round it...
thanks for tryin!
that's the best solutoin i've heard - thanks for that! Stops me sittin round scratchin my ar*#!! :D
