- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
I have just put my car back together for its 1st MOT (under my ownership) and have just discovered a problem that I have inherited from the last owner.
Initially the side lights and headlights were working OK. Go to main beams and the RH headlight went out. I looked further and found that the 15A fuse for the RH headlight was missing (surely without this fuse the headlight should not have worked at all). Replacing the fuse and the main beams worked....yay!! Unfortunately this then meant that the dip beams did not work!!. The previous owner obviously lost his headlights but discovered that removing the fuse fixed the problem in the short term!!! Anyone had this before or have any ideas?
Just to add to the question...may seem a stupid question but mine is a UK car and is equipped with 2 bulbs in each of the headlight units.....what is the outer one for? I have never had these working...is this model complete with Dim Dip? are the 2 connected to my problem?
Thanks for any advice on this....has to be sorted for the MOT!!!
