My clutch has been a right pain in the ass, used to slip occasionally and pedal adjustment hardly helped.
I read somewhere that 89- 91's had a dodgy master cylinder but no one new anything about it and just said i needed a new clutch.
A brand spanking new rps jobby from smithy was installed and i still had exactly the same problem, even tho my Z's very low on power.
Just found this- http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=4610 and this is definately the problem i have. As the day goes on my clutch gets worse and worse then the next morning it will be fine. Infact on Saturday i was stuck on a 3 lane ringroad with me hazards flashing unable to pull away.. a touch embarrassing!
Anywho thought this info may be of use to some of you people out the with clutch problems.
