What gauges?
Going to fit proper boost gauge, poss digital.
What other gauges would be really useful?
tia
oil pressure, water temp are the other main ones then whatever takes your fancy!
Thanx Jaffa.
Was thinking of relying on the std opg and fitting oil temp, 'tho prepared to stand corrected.
3 gauge pod to fill.
Let me give you an example of how good the stock gauge is.
My after market reads 40ºC
Stock reads about 1/3
My aftermarket rises to 60ºC
Stock reads half way
Aftermarket reads 80ºC
Aftermarket reads 90ºC
Aftermarket reads 100ºC
Stock still reads half way
Aftermaket reads 110ºC
Stock still reads half way.
From what I hear you get little warning that your car is over heating on the stock gauge. One second its normal the next it shoots to Hot.
Oil Pressure is a must too. Just on the basis that Nissan sender unit is £80 and a universal replacment for other dials are £7.
Stuart
Right!
So that's Boost Gauge + Water Temp + Oil Pressure
all digital, ok?
(and an oh so cool push button start;) ;) )
So how much will all the cost for digital gauges, also any piccies???
(Won't need the Auto Start seeing as mine don't at the moment *DOH!*)
Here's pic of the Turbo Boost gauge; £42.99
Other gauges are £31.99
Not yet worked out to get pictures actually into the post,
rather by link.
What's the link m8y? :)
Fuel pressure - early warning of impending lean out.
I have never seen a race car without one!
Paul
