I think my exhaust is blowing
Its hard to tell cause its so loud, but after 4 hours in a traffic jam yesterday im sure it sounds a bit like air escaping! Does anyone know if its possible to weld exhausts ? Im not clued up about zorsts at all! The last thing i want is to have to buy another one!
Regards - Mike
Any number of things you can do.
Welding is one, Holts do a range of repair kits (Halfords) which, if you follow instructions work well (best to use one with some sort of binding clamp if you can) you can even cut a section out and slide a piece of slightly larger pipe over the top and clamp it in place.
Over the years have done all the above and they have all worked.
Also look to see where the hole is, it may be on one of the short sections of exhaust, which is chheaply replaced.
If it's stainless then it can be patched by any specialist. If it isn't, go and buy a stainless one!:D :D :D
It is stainless! ! Thank for your help guys! Just gotta find a decent garage to have a look now
