Re-wiring connectors......
I was talking to someone over the weekend, a guy who builds his own cars......Nick Harlett, if anyones heard the name, he must be up there with the best in the country. Anyway, he was just about to wire in the loom to a car he's building at the mo and he said that it is best to crimp the connectors on because if you solder them on, these can go brittle and break/snap over a period of time. I can see his point but was just about to solder on my new injector and coilpack connectors that Stu (SMW1) kindly got for me from Courtesy.
Any opinions on this?
Cheers........
IMO soldering is a far better way of joining wires than crimp connectors.
I would also have said solder;)
small tip...........................
Cut as much wire back on the new connecter as you can,when I had my injector plugs done,the wire was green 5 inches from the old plug:o
I always crimp and then solder if possible. In this instance I would effectively make a new loom for all the injectors and take the wires as far back as possible, all the wiring in the engine bay will have been affected by heat/age and this is a good opportunity to replace some of the really bad bits.
I tend to agree with MrP here. Crimped connectors, done properly, are much better mechanically. Solder won't fair well over continuous extreme heat cycles, like in an engine bay.
Well persoanlly If I was goint to do it properly, I would cslip on some shrink wrap, crimp (but use the connectors without plastic), then solder the connection, then slide the shrink wrap back over it.
The solder method used on your car before james was a temp fix as you know, we used household plug wire IIRC :D :D. But hey, it worked :D.
It did work, you're right, it certainly did the trick.
We (well I) never did get around to soldering them though!
I will crimp then solder me thinks, cheers people.
I love you all. :D (not like that you fookin pervs) :eek:
