Boost Controllers
Hi all,
I've been looking at the APEXi AVC-R and the S-AFC, can these be used together instead of an ecu upgrade or is the upgrade still necessary?
Baz
yes, AFC & AVCR can be used together instead of an ECU (EPROM)upgrade, but it's more expensive and less effective.
A good chip together with the AVCR is a better combo.
-Eric
Even better, if you get a chip, AVC-R and S-AFC. People with this combination have experienced the best results
"Ammar"
a "small" warning: AFC needs to be set up on a rolling road or you run the risk to blow up your engine in notime.
if you get a good chip that has been programmed for your car (on a rolling road), you don't need an AFC.
-Eric
Thanks for the info Lymon - I didn't know that you had to set up the AFC on rolling road and I was just gonna go for it (but now I won't:D )
Thanks once again
"Ammar"
