size of fuel hose
Want to order some braided fuel hose today. Can someone just tell me what diameter I need or does it only come in one diameter.
Thanks.
8mm or 5/16". Make sure it's high pressure hose (~100psi min), although if it's braided it probably is.
Hi there,
I really would only advise you buy Nissan hose, unless you are 110% sure of what you are doing!
I had some fuel hose replaced many years ago, with some strong braided hose, but it still wasn't strong enough. After a few weeks you could see a bulge where it would have bust eventually.
You must check out a manual to see what sort of pressure the system is running before replacing the hose!
be carefull!
Jez.
Fuel pressure is 45 psi :)
before boost or after boost?
I have high pressure 8mm stainless braided hose, think it's rated at 250psi, got it from bsr-aerotek. They also do a lower pressure one with a thinner wall but still adequate.
LOL 45 psi above manifold pressure so max would be 45+whatever boost you are running. Dunno what the pressure is from the pump though at 12v. 250psi stuff would be fine LOL
Don't suppose you have the phone no. do you.
