Finally got my loom fitted on Friday, car started first time fine.....went to set the controllers up and car would'nt start - fuels going through but no spark....ECU diagnostic read code 55, which I believe is no faults??
Any ideas would be greatly appreciated as I need it to race at Santa Pod on Sunday, so I can toast Pete's ass.....;)
Ok Adam, simple stuff first you now fitted 555s so I take it you have changed the ECU chip?
No, I'm using a piggyback fuel controller, and it was running fine for over a month with that setup.....I was leaning towards it being a f**ked ECU though:confused:
FFS I just read no spark:o
PTU mate,first check the connections;)
Cheers mate. The cars still at the garage, but I'm off work tommorow, so I'm going up there to see if we can get the ******* started.....
Originally posted by pete shrimp
Getting in your excuses for another defeat already Adam? :D:D;)
Another in a long line.......;)
Check you haven't overtightened the big connectors for the ECU etc as they can bow out at the edges and cause bad connections.
Does sound like the PTU wiring though.
