For AndyZ
How much would you want for the 2 front tie bars and are the bushes likely to be OK?
What sort of mileage had they done?
Chris
Darron (Ancaster Nissan) had a quick look at the bits when I dismantled it and he didn't find any faults with the suspension.
I'm not technically minded though so could you tell me what these bits you're after look like. I can always get my mechanic round if you dont know. The car had done 60k.
Andy (geewhizz@onetel.net.uk)
If you look in the Online Manual in the Tech section and select Front Axle and Suspension - Page 5
I think it's called the Tension Rod in the diagram but my garage called it the Tie Bar.
I only really need the rubber bushes off the ends but Nissan want £114.00 for each rod as the bushes aren't available on their own. £228.00 for 2 pieces of rubber!
My Z has done about 60000 too so it might be that your bushes are on their way out too anyway.
Mine packed up in time for the last MOT - about 42,000.
Try Luke at the Z Centre - he sells the uprated bushes that I think are made by Suspension Techniques.
Also available from Courtesy, Stillen and JWT.
Courtesy Nissan have them on the main 300ZX page. Didn't even have to search!
$49.00 seems pretty good but I'll call Luke first.
Thanks.
