who does these and how much. i do know that luke does them are there any other suppliers.
i would prefer to use the adjustable ones instead of the spacers. does anyone allready have them fitted as mine is running 3.7 degrees should be nearer 1 degree camber
I've got a Whiteline one on order from Demon Tweeks. They cost£110.53 front and£40.84 rear.
Adam
cheers buddy i will give them a call. are they adjustable ones.
Front: KCA336, rear:KCA347
3.7 degrees negative on the front suggests your top link bushes are worn too. The top link mount studs have plenty length if you want to make up shims for behind the mounts.
Just fitted new Nismo bushes on my top links and the front wheels look very vertical now - not measured tho.
If its on the rear have you checked whether the stock adjustment is already maxed out or still at the oriinal factory setting?
