Hi All
I am new to all this and have just purchased a 300ZX NA, all seems fine apart from having noisy front brakes to over come it i am going to change the pads. Are the Turbo and NA Brake pads the same???? I phoned 3G brakes but they were not sure. Can anyone help??
they are the same. Before you buy, remove the pads, clean everthing up - there should be 2 anti squeal shims behind each pad - one stainless and one metal covered in plastic. Liberal application of copperslip then try again, if they're still noisy then replacement might solve your problem. If you want more info let me know as I've had troubles with my na brakes over the years - so been there, done that...
good luck
Jack
Yeah, but not too liberal application of coppaslip, otherwise it melts and runs all over the wheels, discs etc !
good luck
Jack
Thanks for the Help!
Hopefully now i will be able drive around with the windows open and not be embaressed everytime i brake.
I am sure i will have more questions soon
