Upping the boost
Ok so what is the cheapest/easiest way to do this, and what should i be upping it too, my car has apexi induction, jwt chip, de-cat, large bore exhaust. Years ago people used to install a knob that turned to increase/decrease the boost but i would assume both turbos have to boost the same so how does it all work??
Boost jets bud.
get yourself a pair of 1.0mm mig welder tips.
Theres a tech on TT net on doing it.
Paul
like paul said - boost jets is your cheapest option
you also need to get your ecu chipped, JWT or SE are the safest for uk fuel
also get a decent boost gauge so you know your not running at 20psi!! the stock ones crap.
around 1 bar, 14 psi or there abouts is max on stock turbos
