burf2000 mods part 2
Well your thought my superchager thing was funny
now part 2
I brought of the web a piggy back chip thingy
Its called a IAT timing trick and as far as i can see its a resistor and is suppose to go on the lead that would plug in to the air box
well its suppose to tell the pcm that its taking in 57 f temperature air and that may give up to 1.5 degree in increased timing
Wow sounds fun
Whats does it mean in english
I brought it for a joke and cost be $3 (good quality product)
We did this on a 2.5 V6 Mondeo & it actually worked, not sure I'd want to risk it on the Z though :eek:
Well what does it do
Do you just unplug the cable from the air sensor and plug it in to that
No idea on Z, on the Mondeo we had to cut the wire & solder it in
I know an ever cheaper solution:
Set the CAS to 17 BTDC (on a TT this can lead to detonation though)
Whats that mean in english mate
Set the timing to 17 degrees by turning the Crank Angle Sensor (You'll have to use a timinglight to do this)
I dont want my car going bang
LOL!! then dont fit that!!
seriously though, is there an air temp sensor on a zed?? as it has an Air Mass Sensor, its usually internal in this. (dont know for sure - cant be arsed to check ) :D
I'd stop fitting crap to it then if I were you.
Tim :D
Someone should try this stuff out for other people so they no if it is a good idea
eg. i was not the only one on the forum thinking of fitting a electronic supercharger
