RichardS ·
Anyone ever had a noisy wheel bearing?
My late (96) import tt (only 38k) has a horrible bearing noise which sounds like a front wheel bearing to me.
My local main agent will only say "yes there is a noise, let it develop"
Hope it isn't anything worse. Anyone any experience of noisy wheel bearings on tt's?
