In memory of Mandy
WET Patch
I have a wet patch on the passenger side footwell and the windows have steamed up ??? is the heater matrix shagged or is there something else under there ??? :mad:
Any advice would be appreciated..........Dave..
Or it may if you lucky be a clogged up air con drip tray pipe,having had same symptoms myself on previous Z,Tony
i had a simular problem on my old zed.......the drain had blocked at the bottom of the air-con.matrix and was dripping water on to the ECU.........which was not nice?:eek:
