Nismo FPR
Quick question for the people that are in the know.
Just looking at the courtesy web site and i see there in an adjustable Fuel Pressure Regulator , (£85) would this be a suitable alternative if you wanted to run 16-17psi or would you need to go to 555 injectors
if this is a suitable alternative how much would you have to raise the pressure and would this shag the injectors ????
I tried running an fpr, but I've had to bite the bullet and buy 555's. However thats 'cause I'm looking to run 1.5 bar (21-22psi). I used to run 1.1bar (16psi) on just the standard injectors, without fuel pressure regulator, but with the fuelling controlled by an Apexi S-AFC.
Cheers for that Adam what adjustable FPR were you using ??
A nasty FSE one. With a free annoying noise;)
I see that would be the FSE power boost valve then
Who set your Apexi S-AFC Up
DPmotorsport
