Rear Fog lights
Anyone know an idiots guide to setting up fogs in one side of the reverse lights.
My J spec has them run through the inner rear brake lights but they now dont work for some reason so im goingto put that back to stock and start again if possible.
All help appreciated, MOT due 13th of next month:(
If you use a relay you can use the inner brake light as a brake light and override it when the fog lighs are turned on.
my Jap import uses the high level brake light as a fog light. It's connected up just behind the drivers head - remove the targa, remove the rubber seal, and there's the wires to the lights. Find the high level wire and split it and wire to the added fog switch on the dash. I have this made easy so that at MOT time I connect it and I have a fog light, then I disconnect it after the MOT and I have a high level break light.
...good luck.
Jack
Many thanks, mine had a relay on it before but it only lit up the outer brake lights when braking and the fogs when you turned them off but i took the relay out as it was attached to the stereo cage and kept making my stereo cut out.
Can see this may take me some time and a few bulbs and feses!!!
