In memory of Mandy
clutch
My clutch recently packed in as the slave cylinder was nackered so i ordered a new slave cylinder from nissan. I had the part fitted and am in the process of trying to bleed the system but am having no luck in getting a clutch peddle back. I have a ninety pound vacuum bleeder kit but cant seem to get a clutch peddle can any one help with my predicament. There might be something i dont know about. I have thought i might have to change the master cylinder aswell.
please please help car been of road for almost two weeks now.
Missing it
Harp69
__________________
harp.zx
I had to change the master after changing the slave and it not solving the problem.
the way i done it
let the fluid run out of slave cylinder ..... tighten
go to the bleed nipple in front of engine bay (beside power steering resovior) get somebody to press downb on clutch ... release bleed nipple & retigten ... .... u know the way i mean ?
go back and forth doing both of the nipples ..... slave as well !
remember if the fluid goes down to low ... even for a slpit second that u r back to the start ..... i couple of clutch pumps will empty the resovoir !!!!
hope this helps :)
Thanks for your replys we mananged to find the bleed nipple at the inner wing and have bled the system from both points and bingo im back on the road. You learn something new everyday.
Thanks Again
__________________
harp.zx
:p :p
