Flushed my radiator today.
Got this stuff in 2 bottles. In the end you end up flushing the thing about 7-8 times because its, empty, full with water put content in, idle for 30 mins, empty, fill with hot water, run for 5 mins, flush water and then fill with cold water, then bottle 2 with doing the same. Took a good 2 hours to do it.
But the water that came out was all greasy and yucky at times.
Worth doing though I think. 1 less you know you have done, and it seems to cool my engine better.
Stuart
sounds like a good job done there
Know what you mean about 8 flushes did mine last week , same thing with the cleaner and conditioner takes ages but well worth it
I've often thought about this for ones bowels too, but its too damn scary.
oh and to save anyone else having to say it:
I know im full of sh*t ;)
Apparently there can be bits in you which has been there for years. Nastly thought.
Still doesnt want me to go out and have tube of warm water stuck up my arse.
Stuart
I thought using any sort of radiator flush was bad for the heater matrix:confused: :confused:
Vijay
Dont. Cant see why not?
It doesnt go hard or anything, it just dislodges any bits that got stuck in the system. Apparently Anti Freeze congeals (sp) over time.
I think it worked because there where small bits that came out
Stuart
The theory is small particles get lodged in the matrix causing it to block and then you get pressure build up and then it goes, if the electrical leak shortage doesn't get it first?
Colonic irrigation anyone ?;)
Jock,
just used halfords own brand
as regards particles i flushed mine because the heater matrix started leaking so i bypassed it and one of the hoses from the back of the engine to the matrix was nearly fully blocked with crap , probably why the heater matrix is buggered:(
