Gearbox oil
Being half way through a clutch change, ive managed to lose some gearbox oil, just wondering what stuff i should refill with?
Also do i just pull oout the plug on the drivers side and fill until it comes out?
check here for refilling instructions. if its a TT with cooler & pump, then after filling you run the pump & recheck/refill.
i used 80/90 gear oil.
Cheers very much Paul, especially useful that pump info, i wouldn't have done that and thus probably would have had a half empty box!
I bought Castrol Driveline "syntrax universal" 75W-90 from halfords, they didnt have a Z listed but just bout every other car it said use this.
Will b Ok?
