just wondering what controls the single press up/down control on the drivers side window? Mine seems to now only want to work part time:(
Vijay
There is a control box/reley below the switch.
Mine didnt work at all and a new reley solved that.
I took mine apart & soldered up a dodgy connector, cleaned the contacts in the relays & it works fine now:)
mine is also buggered.. i took the door panel off and when i press the switch the relay makes a 'clicking' noise - if i hold the button down eventually a faint 'click' comes from where the motor is.
Do you think this means the relay is fine but the motor is buggerd?
if the motor is naffed is it hard to get at after taking the main door panel off, and any ideas where to get one?
why now this happens - when the whethers fekin boiling doh.
