front tyre wear?
has any one have excessive front tyre wear.Inner edge's like the tracking's toeing in heavely....I hane recently had my tracking checked which was fine and all bushes are fine any Idea's ?
Normally a camber problem, do you have non-standard wheels or suspension ?
Zeds only done 53'000 kph standard wheels and suspension?
probably camber, can be adjusted, get it checked at a good tyre olace with one of those complete laser set up things.
They have all the settings programmed in, and give you a nice print out of what your settings are against what it should be.
Cost of correcting varies depending on whst they have to do.
I paid ยฃ50 to get mine set up to spec., but with slight neg. camber, and this covers both front and rear.
I used Protyre in Bristol. when they put new boots on.
Cheer's at least one helpfull reply....i will do that...
rear camber is adjustable - front is not!!
if the front camber is out of spec & you want to adjust it, there is a camber adjuster kit available which brings the top arm out to reduce negative camber if that is the problem, or you can get replacement adjustable upper arms.
you need to have a 4 wheel alignment done 1st to see what the problem is. ;)
Cool infor people as when i got my car MOT`ed they said i had inner wearing and they were new tyres
So i need to take it to a good tyre place to get the camper done as mine is standard
But front camber is non-adjustable as long as you have standard Nissan suspension.
oh so how do i fix it
erm, like what i said in my post??? :confused: ;)
