big hole
could do with a bit of advice guys.import zed big hole in center consul mid-rail missing no guts behind, id like to fit new head etc ,any clues nothing to fit to?
I would ring andy z, his no is on the bulletin board traders area, see if he has a second hand one, its quite easy to take out, hidden screws on the top each side of vents, then should lift out if i remember rightly, replace it with new one as i dont think theres another alternative really, unless you buy a double din head unit, or a big fat sat nav, good luck, by the way what did you buy ???? hth
