safety boost question
If you were using boost jets and went into safety boost would the boost drop to 7psi or would it drop 2-3psi below what you were previously boosting ie from 14 to 11-12
also can you go in to safety boost if there are never any error codes
i'd say 7 psi but helps if you have an aftermarket boost gauge,stock is crap as everyone no's
Thanks for the reply J300zxturbo
Think your right mine runs at
5psi in safety boost
7psi in normal conditions without jets
12psi with 0.8 boost jets
thought perhaps i was running in safety boost as i am loosing approx 2psi in every instance :confused:
using aftermarket boost gauge so pretty accurate
