air con
Ok ive been messing about 4 six months now can some one please tell me whats what on the air conditioning control,eg auto,rec,etc!
Jon
Auto: Press this and the Air Con will blow hot or cold air to make the temperature inside the car the same as the one selected.
Rec: Recirculate, press this and the Air Con will take air from inside the car for use. This is good for when its too hot or too cold. Cooling down already cold air from inside the car give a better result than using 25C outside. It is also good for when you are through an area which smells or stuck behind a smelly truck. If activated will return to normal mode after 20mins or so for safty reasons.
Eco: Economy mode. This doesnt use the Air Con compressor which means it wont use more petrol like normal Air Con does. This means that the air that comes out isnt as cool as it would normally be.
Off: Turns it off ;)
Hope this helps
Stuart
Thanks mate, thats pretty much what i thought ,best to check though! :)
